Remote Support Facility
Learn about using the Remote Support Facility, an application that runs on the HMC and enables the HMC to call out to the service and support organization, after you enable it.
The connection between the HMC and the remote facility can be used to:
To find out how the Remote Support Facility fits into your service environment, see the Map of service applications and functions.
