Use this procedure to perform i5/OS® problem analysis.
If you experience a problem with your i5/OS system or logical partition, gather more information about the problem to either solve it, or to help your next level of support or your hardware service provider to solve it more quickly and accurately.
This procedure refers to the i5/OS control language (CL) commands, which provide a flexible means of entering commands on the i5/OS logical partition or system. You can use CL commands to control most of the i5/OS functions by entering them from either the character-based interface or iSeries® Navigator. While the CL commands might be unfamiliar at first, they follow a consistent syntax, and i5/OS includes many features to help you use them successfully. The CL topic includes a complete CL reference and a CL finder to look up specific CL commands.
After reviewing these considerations, follow these steps:
