Learn how to update or upgrade server firmware and power subsystem firmware (if you have a model 575 or 59x server) through an HMC when you have an Internet connection from the HMC or server.
You must install HMC updates before you install server firmware or power subsystem firmware updates so that the HMC can handle any updates or new function that you apply to the server. After you install HMC updates, either install the power subsystem firmware and server firmware updates together, or install the power subsystem firmware first (if you have a model 575 or 59x server), and then the server firmware second.
Perform tasks 1 through 6 to obtain server firmware and power subsystem firmware updates (if you have a model 575 or 59x server).
To verify that the service connection is working, perform the following steps:
The level of machine code on the HMC will determine the available features, including concurrent server firmware maintenance and enhancements to upgrading to a new release.
To update a current release or upgrade to a new release, follow these steps:
Notice: Do not perform any configuration or management operations on the managed system while Licensed Internal Code is being updated.
If the following message is displayed on the HMC interface, you will need to manually shut down all of the applications and logical partitions to prevent the system from shutting them down abnormally during the process. Quiesce any applications currently running on your operating systems for the systems listed below.
At the end of a disruptive process, the managed system automatically returns to its original state.
