ESA0xxxx Electronic Service Agent™ error codes
These error codes can be displayed in a window that is displayed on the HMC screen during system configuration and operations.
ESA0xxxx error codes Message Recovery action
ESA00001 You must enter a valid IBM® ID.
ESA00002 Issuing authorization request for the following IBM IDs: {0}
ESA00003 Issuing authorization request for the following IBM ID's: {0}{1}
ESA00004 Your Hardware Management Console is not currently configured for remote service. Ensure that this Hardware Management Console is configured for remote service under Remote Support. See Enabling remote support on the HMC.
ESA00005 The application can not currently find access to a call home server.
Ensure that one of your Hardware Management Console's is configured as a call home server under Remote Support.
ESA00006 Your Hardware Management Console is not currently configured for remote service and can not currently find access to a call home server. Ensure that this Hardware Management Console is configured for remote service and that one of your Hardware Management Console's is configured as a call home server under Remote Support. See Enabling remote support on the HMC.
ESA00007 Remote Support is not currently supported on this Hardware Management Console.
ESA00008 A request to authorize users was successfully created.
ESA00009 An attempt to create an authorize users request was unsuccessful.
ESA0000A You must select an email address to perform the desired operation.
ESA0000B Successfully removed the following email addresses: {0}
ESA0000C Successfully sent email to the following addresses: {0}
ESA0000D Transmit of email request was unsuccessful. Ensure that the SMTP server and Port number specified are correct.
ESA0000E A request to transmit service information has been successfully created. Once the data has been gathered it will be transmitted.
ESA0000F Successfully updated the frequency and time when the scheduled transmission of service information will occur.
ESA00010 Successfully updated settings.
ESA00011 Unsuccessfully sent email to the following addresses: {0} Ensure that the email address(s) is specified correctly and retry the operation.
ESA00012 When you enable email notification, you must specify both an SMTP server and port number.
ESA00013 A request to transmit performance management information has been successfully created.
