Disk drive and solid-state drive system parts
Disk drive and solid-state drive system parts information.
| CCIN | Part number | Description |
| 59E0 | 00E9906 | 283 GB 15K RPM (528 block size) small form factor SAS disk drive (IBM® i) |
| 59E1 | 00E9966 | 283 GB 15K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 5B41 | 01LU575 | 283 GB 15K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 59E0 | 00E9912 | 300 GB 15K RPM (528 block size) small form factor SAS disk drive (AIX® and Linux®) |
| 59E1 | 00E9972 | 300 GB 15K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 5B41 | 01LU579 | 300 GB 15K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 59D0 | 00E9894 | 571 GB 10K RPM (528 block size) small form factor SAS disk drive (IBM i) |
| 59D3 | 00E9951 | 571 GB 10K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 59E5 | 00E9968 | 571 GB 15K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 5B45 | 01LU576 | 571 GB 15K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 5B47 | 01LU584 | 571 GB 15K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 59D0 | 00E9900 | 600 GB 10K RPM (528 block size) small form factor SAS disk drive (AIX and Linux) |
| 59D3 | 00E9959 | 600 GB 10K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 59E5 | 00E9974 | 600 GB 15K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 5B45 | 01LU580 | 600 GB 15K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 5B47 | 01LU588 | 600 GB 15K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 59DB | 00E9953 | 1.14 TB 10K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 59DB | 00E9961 | 1.2 TB 10K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 59DE | 00E9954 | 1.71 TB 10K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 59DE | 00E9962 | 1.8 TB 10K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 5B13 | 00LY333, 00LY603, 01LU868, 01LU931, 02YC570, 02YC680, or 02YC878* | 387 GB (4224 block size) small form factor solid-state SAS drive |
| 5B19 | 00LY324, 00LY577, 01LU863, 01LU920, 02YC565, 02YC675, or 02YC873* | 387 GB (528 block size) small form factor solid-state SAS drive |
| 5B14 | 00LY334, 00LY604, 01LU869, 01LU932, 02YC571, 02YC681, or 02YC879* | 775 GB (4224 block size) small form factor solid-state SAS drive |
| 5B1A | 00LY325, 00LY578, 01LU864, 01LU921, 02YC566, 02YC676, or 02YC874* | 775 GB (528 block size) small form factor solid-state SAS drive |
| 5B2B | 00LY559, 01LU805, 01LU902, 02YC595, 02YC646, 02YC705, or 02YC844* | 931 GB (4224 block size) small form factor solid-state SAS drive |
| 5B15 | 00LY335, 00LY605, 01LU870, 01LU933, 02YC572, 02YC682, or 02YC880* | 1551 GB (4224 block size) small form factor solid-state SAS drive |
| 5B20 | 00LY374, 00LY560, 01LU806, 01LU903, 02YC596, 02YC647, 02YC706, or 02YC845* | 1860 GB (4224 block size) small form factor read intensive solid-state SAS drive Note: Replacement of the read intensive solid-state
drive (SSD) might not be covered by the system's level of service entitlement, depending on the
terms and conditions of the system. For more information about read intensive SSDs, see Read
intensive SSDs.
| 5B2C | 00LY561, 01LU818, 01LU904, 02YC597, 02YC648, 02YC707, or 02YC846* | 3720 GB (4224 block size) small form factor solid-state SAS drive |
| 5B2E | 01LU807, 01LU905, 02YC598, 02YC649, 02YC708, or 02YC847* | 7450 GB (4224 block size) small form factor read intensive solid-state
solid-state drive (SSD) might not be covered by the system's level of service entitlement, depending
on the terms and conditions of the system. For more information about read intensive SSDs, see Read
intensive SSDs.
| * Order the same part number as the drive that you are replacing. | ||
| 19B1 | 74Y6497 | 283 GB 15K RPM (528 block size) small form factor SAS disk drive (IBM i) |
| 59C9 | 00E8681 | 283 GB 15K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 5B43 | 01LU583 | 283 GB 15K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 19B1 | 74Y6498 | 300 GB 15K RPM (512 block size) small form factor SAS disk drive (AIX and Linux) |
| 59C9 | 00E8687 | 300 GB 15K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 5B43 | 01LU587 | 300 GB 15K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 19B3 | 74Y4899 | 571 GB 10K RPM (528 block size) small form factor SAS disk drive (IBM i) |
| 59D2 | 00E9935 | 571 GB 10K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 59CF | 00E8660 | 571 GB 15K RPM (528 block size) small form factor SAS disk drive (IBM i) |
| 59CC | 00E8683 | 571 GB 15K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 19B3 | 74Y4901 | 600 GB 10K RPM (512 block size) small form factor SAS disk drive (AIX and Linux) |
| 59D2 | 00E9943 | 600 GB 10K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 59CF | 00E8665 | 600 GB 15K RPM (512 block size) small form factor SAS disk drive (AIX and Linux) |
| 59CC | 00E8689 | 600 GB 15K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 59CD | 00E8623 | 1.14 TB 10K RPM (528 block size) small form factor SAS disk drive (IBM i) |
| 59DA | 00E9937 | 1.14 TB 10K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 59CD | 00E8631 | 1.2 TB 10K RPM (512 block size) small form factor SAS disk drive (AIX and Linux) |
| 59DA | 00E9945 | 1.2 TB (4224 block size) 10K RPM small form factor SAS disk drive (AIX and Linux) |
| 59DD | 00E9938 | 1.71 TB 10K RPM (4224 block size) small form factor SAS disk drive (IBM i) |
| 59DD | 00E9946 | 1.8 TB 10K RPM (4224 block size) small form factor SAS disk drive (AIX and Linux) |
| 59E8 | 00E8710 | 387 GB (4224 block size) small form factor solid-state SAS drive |
| 5B10 | 00LY336, 00LY621, 01LU865, 01LU928, 02YC567, or 02YC677* | 387 GB (4224 block size) small form factor solid-state SAS drive |
| 5B16 | 00LY327, 00LY589, 01LU861, 01LU918, 02YC563, or 02YC673* | 387 GB (528 block size) small form factor solid-state SAS drive |
| 59C3 | 00E8713 | 775 GB (4224 block size) small form factor solid-state SAS drive |
| 5B11 | 00LY337, 00LY622, 01LU866, 01LU929, 02YC568, or 02YC678* | 775 GB (4224 block size) small form factor solid-state SAS drive |
| 5B17 | 00LY328, 01LU623, 01LU862, 01LU919, 02YC564, or 02YC674* | 775 GB (528 block size) small form factor solid-state SAS drive |
| 5B12 | 00LY338, 00LY623, 01LU867, 01LU930, 02YC569, or 02YC679* | 1551 GB (4224 block size) small form factor solid-state SAS drive |
| 5B21 | 00LY373, 00LY554, 01LU803, 01LU899, 02YC592, 02YC643, or 02YC702* | 1860 GB (4224 block size) small form factor read intensive solid-state SAS drive Note: Replacement of the read intensive solid-state
intensive SSDs.
| 19B1 | 74Y6498 | 300 GB 15K RPM (512 block size) small form factor SAS disk drive (Linux) |
| 19B3 | 74Y4901 | 600 GB 10K RPM (512 block size) small form factor SAS disk drive (Linux) |
| 5B16 | 00LY327, 00LY589, 01LU861, 01LU918, 02YC563, or 02YC673* | 387 GB (528 block size) small form factor solid-state SAS drive (Linux) |
| 5B17 | 00LY328, 01LU623, 01LU862, 01LU919, 02YC564, or 02YC674* | 775 GB (528 block size) small form factor solid-state SAS drive (Linux) |
| 5B29 | 00LY553, 01LU802, 01LU898, 02YC591, 02YC642, or 02YC701* | 931 GB (4224 block size) small form factor solid-state SAS drive |
intensive SSDs.
| 5B2D | 00LY555, 01LU817, 01LU900, 02YC593, 02YC644, or 02YC703* | 3720 GB (4224 block size) small form factor solid-state SAS
drive Note: Replacement of the read intensive solid-state drive (SSD) might not be covered by the
system's level of service entitlement, depending on the terms and conditions of the system. For more
information about read intensive SSDs, see Read intensive
SSDs.
| 5B2F | 01LU804, 01LU901, 02YC594, 02YC645, or 02YC704* | 7450 GB (4224 block size) small form factor read intensive solid-state SAS
SSDs.
| 5B1D, 5B48 | 00LY299 | 4 TB 7.2K RPM (4224 block size) large form factor SAS disk drive (AIX and Linux) |
| 5B1F, 5B49 | 00LY301 | 8 TB 7.2K RPM (4224 block size) large form factor SAS disk drive (AIX and Linux) |
| 5B1D | 00LY299 | 4000 GB (4224 block size) solid-state SAS drive |
| 5B48 | 00LY299 | 8000 GB (4224 block size) solid-state SAS drive |
| 5B1F | 00LY301 | 4000 GB (4224 block size) solid-state SAS drive |
| 5B49 | 00LY301 | 8000 GB (4224 block size) solid-state SAS drive |
