What makes a strong test management system?
As testing requirements expand in number and complexity, advanced quality management solutions can help engineering teams integrate continuous testing across all development stages in the process. Ultimately, a strong test management system not only helps your teams meet project timelines without sacrificing quality, but helps you get to market faster while optimizing the quality of the end product along the way.
Improve time to value, minimize risk and reduce project costs
See how a comprehensive engineering lifecycle management solution can help your enterprise be more compliant and transparent.
What can I do with test management?
Improve product quality through continuous testing
Test early and often with an integrated development process to find issues when they’re relatively inexpensive to fix. You’ll get to market faster, lower development cost and improve product quality.
Deliver your product with confidence
Reduce the overall time and cost of software development with defined, repeatable processes that can delineate workflows, inputs, outputs, roles and responsibilities.
Streamline industry compliance
Overcome challenges with industry compliance and ASPICE standards with the new automotive offering in the IBM Engineering Lifecycle Management (ELM) portfolio.
Synchronize your requirements and test management
Pinpoint test cases impacted by changes to requirements with automated traceability. Integrate across the entire engineering lifecycle to improve decisions and product quality.
Products behind this solution
IBM Engineering Test Management
Deploy comprehensive test planning and test asset management from requirements to defects with this collaborative, web-based, quality management solution
IBM Engineering Requirements Management DOORS Next
Capture, analyze, trace and examine relationships between requirements and tests. Optimize communication, collaboration and verification of requirements to remain compliant.
Client success
Panasonic Automotive collaborates to quickly test and address defects
The leading manufacturer of automotive systems used IBM Engineering Lifecycle Management software to connect global partners instantly to collaborate, deploy the same tools and share testing across teams, allowing them to close as many as 200 defects in a 24-hour cycle
